frogeyeman
Me again. On one of my s25 engines the roto start will not turn the engine. Removed the roto start back plate and the shaft that the OWB sits on just turns as if it is not engaging with the crank pin. if you push the shaft in it engages but on turning the engine it disengages. Removed the backplate assembly and the crank pin looks as if it is too short. Saw a video on You Tube and that crank pin looked about the same. Here are the pictures of the innards of the engine. Hope you can help or is it scrap. A good running engine.![IMG_20260504_212044336_MFNR_HDR[1].webp IMG_20260504_212044336_MFNR_HDR[1].webp](https://www.hpisavageforum.com/data/attachments/22/22836-fd7fe177a91cff32a72086f1b637eee6.jpg?hash=qS4JfJvA5X)
