Hi guys, I have recently had a problem with my reverse module which seems to be getting worse with time.
I cannot use it at all now, it is as if I am in neutral. the engine will scream and I may get a foot in reverse then the gears crunch and the engine screams again.
It all began happening after the below video.. I had a quick look under the truck last night, all the grub screws are in place and nice and tight. What I did find though is that the silver metal plate that sides in and out of the gear box seems to be very loose. I guess that this is more than likely damaged.
I am guessing you’re going to tell me to remove the gear box and take a look; well that is my next move. I had a busy day at work today so I wanted a relaxing evening before a busy weekend.. so I won’t get a chance to look at this until Monday! Just thought someone may have had the same problem and can offer some advice?
