Reverse mixer
Djliveasy
Manchester
Right trying to install my reverse mixer, following the instructions but It just will not move the extra servo for reverse, what could this be, the led is blinking as it should, carnt work it out
Are you holding the brake for atleast 3 seconds, letting go, then reapplying throttle? That's how that mixer engages.
Tried everything just doesn't seem to set up, ive had the servo moving, but just wont do anything when I'm holdind the brake
Have you followed the directions completely? some of these can be a bit tricky to get setup and it may take a few tries to get it right..... you may not be able to tell if it engages reverse mode until you have it running and working in forward. all I can say is to keep at it until it works.....
Like X stated above, hold brake for AT LEAST 3 seconds until it engages the reverse mode, throttle will remain the same but you should be able to see the reverser engage at the point it switches...
