Repacing spur gear and pinion
scrofcheck
Hi Today I was replacing the spur and pinion gear and when I put the engine on the frame I noticed it's not exactly level. Appears to have a downward slant. Nothing appears bent seems like this is the way it's supposed to be, but it doesn't look right. The only reason I noticed this was because I took the side plate off to set the gear mesh. Is this normal? Thanks
You mean the clutch bell and spur? If so your motor mount if it has it a set screw for the front on the mill will help level it out. Hope this help's.
Update Well it turns out my engine support was bent. I bought a new one
and all appears to be good. Thanks
