I recently upgraded my steering servo to a hi tech 645mg ... ITS AWESOME
but Iam not sure if I just need to get used to it or what b/c my steering is VERY touchy. I can hardly control this darn thing. Does anyone else have this issue ?
SJ.
Assuming that you've already setup the servo to be zero'd and centered,...
What size rims and tires you running?... What kind of TX?
There are three things that come to mind that could help, in this order.
Try one step at a time and check for improvement before going to the next step.
1, Make sure that your front end toe-in is setup equally and not too extreme.
If you have road tires on, go for a 1/2 degree toe-in or less.
2.Reduce some tension at the steering servo abit and see if there's any improvement.
An over tightened servo saver can be very twitchy.
Try to find the sweet spot for the servo saver. Once you found the spot, put a drop of
thread lock on the servo savers threads.
This will preserve you setting by preventing unwanted movement.
3. If your TX has end-point adjustments, reduce the end points on the steering abit.
These things if propperly adjusted should help.
Keep in mind that unless you'lve upgraded all your steering linkage and steering
arms, the savage by nature is an off road truck and doesn't respond in a precise mannor
on the street.
Does your servo arm have more than one hole in it?
Try a hole closer to the servo screw. Just a thought.
right now iam running the stock tmaxx tires and rims ..
Site Jester:
AAAAAAAAAAAAAAAAAAAAAAAAAGH !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
so..... How they holding up?..lol
Well now....If I'd known you was using them tires your running,... That would explain the squirly turnning issue.
Those Maxx tires are small... Thats gonna make your truck turn on a dime!!
Not to mention... People will throw rocks at you from a far distance for putting those things on your truck...lol
Just kidding , bro.lol
What happened to the stock tires?
......... but yea have a good laugh on me it's all goodWelcome to HPISavageForum, a friendly forum to discuss the Savage RC Truck.
