Rearward
bobbd
Hey guys i have 2 savages x 4.6 i just noticed i can roll one forward and backward but the other one will only roll forward it will not go in the opposite direction. They are both 2 speed trans with no reverse.
Will the spur gear spin in both directions? If not, could be the CB bearings are seized or the shoes are damaged and jamming up the bell. You could try loosening the engine and moving it over so it doesn't mesh with the spur to see if it then rolls in both directions. Then if it still doesn't, then something is messed up inside the trans.
Didnt get to loosen motor yet but when i put a little more force pushing it rearward it will reverse with a clunking sound while moving freely backwards then tightens up sgain with clunking sound
Finally got to loosen motor and move it away the truck still binds up going rearward with engine out. I guess it s the trans any tip or advise what to look for besides the obvious such as stripped gears , metal fragments ,?
