Question
fouteros
Grecce
hello,
i bought a lrp zr.30 ( i will post a review) and i am in the 5th tank
now these is something that i noticed:with the engine shuted i cant pull the truck backwards
i mean that the truck doesnt go back if i push it
other than that no problem
please tell me what this is
thanks
Does it go forward if you push it?
Sounds like the brakes are engaging at idle. Fix your linkages so that the brake arm is straight up when at idle.
BTW: You should make a new thread.
Something is binding in your drivetrain or on the clutchbell. When you roll the truck backwards, the spur gear should spin, rolling it forwards the spur will not spin.
