I think you will have to do some disassembly to find and fix the problem.....
So i took apart the back end and got it all opened up and to be hounest don't know what I'm looking at. i noticed that theres groves inside the shaft holder but none on the shaft that goes into it from the pull cord. i didnt notice any springs l.lo so i geuss it didnt pop out at me So what you guys think? I can post pics if it helps also
So i took apart the front end and got it all opened up and to be hounest don't know what I'm looking at. i noticed that theres groves inside the shaft holder but none on the shaft that goes into it from the pull cord. i didnt notice any springs l.lo so i geuss it didnt pop out at me So what you guys think? I can post pics if it helps also
K
Gotta take the pully back out.give me a few mins
What piece is the one way bearing?jvt can probably help better, I'm not familiar with k motors, I would guess one way bearing may be bad, looks like all parts are there. , that is a general cause of not working.one way bearings don't last with a lot of cranking.
I googled itWhat piece is the one way bearing?
Question
I notice on the Diagram for the Savage XL.that they used an sealant On the screws that puts the metal piece back onto the engine block. should I do the same if this time around everything works out?
Since you have your torn down partways you may as well just remove it and do a good cleaning and lube before putting it back in. I see enuff grit and gunk to get all kinds of crap into it at this point.....
Also post a couple of pics of the block and head so we can tell what 4.6 you are working with, (there are several variants of the 4.6 engine)
Weres a good place to do one stop shopping online for parts and oils?I don't have any name brand lubs on hand. I have gun oil and wd 40.would ether of those do? Also what do i lube withen the engine?
View attachment 3181 I'm taking apart the back end and this appeard on the table.ive been carfully taking pitures and organizing parts and screws but i can fig were this would go.
