Problem with reverse Flux V2
LangeBen
Germany / Netherlands
I'm having trouble with going in reverse with de Flux V2.
The motor and ESC are the standard ones that came with the truck.
Trims for forward and reverse on the remote are at 100%.
There are no problems with forward en brakes.
When i want to go in reverse slowly i see the light on the ESC get red but the truck stays stil.
When i give it full reverse it go, but on full power, after that it wil go in reverse even with a bit of power.
I have done the ESC setup procedure multiple times.
I use the Absima CR7P remote and 7 ch reciever in the truck and on other cars with no problem.
And i have rebind the reciever with the remote.
I installed the original reciever and remote but the problem is the same.
Anyone got an idea what the problem might be?
Checked the cables? Any funny smell coming outta of ESC? How many red flashes you get? Have you checked the number of red lights against the chart on page 39 of manual?
The cables are good, the ESC smells like warms electonics.
On startup the ESC flashes 1time red and 6 times green (6S) if the remote is off it flashes red, if the remote is on it wil burn red on forward, break and reverse and off on neutral.
the learn in process it wil blink 1 time on neutral, 2 times on forward and 3 times on reverse and 3 times after that when finishes.
Page 39 is the partslist in my manual so don't know to what part you are refering
Still it go normal on forward and break, and the first time revers i need 70% to go after that it can go slow reverse.
