ShiftPoint
- Ft. Laduredale, FL
Hi,
Just wanted to guibve you guys a heads up on this part.
I bought one of these OFNA fan flywheels and found a problem while installing it, actually when putting the clutch springs on. the pilot nut sits too low on this flywheel so the springs don't mate up with the groove on the nut, the groov is too low. How low you ask, well a couple washers would do the trick. You can see the difference in these pictures
here's the problem OFNA part I am having a problem with, note the area where the pilot nut touches the wheel, there is no raised area like in the HPI one
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXPF82&P=7
Here is HPI's, see the raised area in the middle
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNZM7&P=7
this one looks like it would be ok too
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKAY8&P=7
I don't have any washers that will fit "exactly" in place, at the kind of rpm's on this I wouldnt want any slop in it at all. Also the springs are pretty far off, I wouldnt trust it as it is. Guess I will have to go back to the HPI flywheel...
