- Worthington, MN
OK I'm feeling stupid here but I recently purchased a set of 4 Pro-line crime fighter tires #1121 http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKYL7&P=ML but the specs say that:
A Mounting Width (in.) : 0.94
B Mounting Diameter (in.) : 3.11
C Tire Width (in.) : 2.72
D Tire Height (in.) : 5.65
Tire Weight (g) : 153
Here is the wheel specs as well:
Diameter: 3.3" (84mm)
Width: 2" (51mm)
Offset: 1.1" (28mm)
Hex Size: 0.67" (17mm)
I have also got a set of these ( http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLMZ9&P=M ) wheels that I was planning on putting them on but I put the tire over the wheel with out the foam and it looks like the side wall is sticking out vary far and weird looking. Maybe its because I don't have the foam in them?
Am I doing this correctly??
I will try to get Pict's later.
Width: 2" (51mm)
Offset: 1.1" (28mm)
