Hi,
I have justed fitted a Axial .32 into my old savage .21
I have changed the diffs, Axial 18 tooth clutch bell and 3 Aloy shoe clutch, 47 tooth spur gear, changed the pipe to a polished pipe, I have changed the servos, throttle and brake linkage. Big air filter and fuel filter, & using stock rims and tyres. Also I sealed the engine before fitting.
I have just finished breaking the engine in (with 5 tanks of fuel) also I have opened the LSN 1 and a half turns as advised to lower the running temp. I took it out today to tune, and before I started to tune when accelerating it goes well but bogs down before hitting 2nd and stalls :duh: also it does not realy come that close to pulling a wheelie?? I'm not sure if it is stuck in 2nd as the gear box is still on the settings for the savage .21
Is it the engine needs leaning or is it the gearbox?? or any other sujestions.
