Picco .28 glow plug
AERC78
What glow plug works best for the Picco .28 engine on 30% nitro?
well as its a given rule you usually run a cold plug with 30% due to the higher percentage of nitro. i would use McCoys cold plugs.
the mccoys are the longer better sealing normal glow plugs. if you have the coin you can get the turbo headbutton and run turbo plugs which i know nothing about but they do have different plugs and are more expensive tho there's reports that it dose increase some power...
