I haven't found the correct string for it so I wound up purchasing a whole new assembly, I love to rebuild them even when the springs break. I went to the hardware store and bought #1 braided nylon masons line, wound up breaking it over and over again about 8 times in a 3 hour period, each time restringing it...if anyone knows some good solid string for these pullstarts please post a link for me. ill buy a thousand feet of it lol
just use associated pull start rope... works for me
Pink I pull off the rear end of the truck and leave the mill in the chassis. depends on your tools. Picco pullstart is the easiest to rebuild I have found
The roto start for the S25 will work, you will also need a 12mm wheele hex to fit inside the roto assembly to keep the spring in line.
Thanks to Grumpy for the info on the hex.
