on board failsafes
f1n3sse
philadelphia
Ok so I have an ofna micro failsafe and I'm starting to really starting to hate the thing. it makes my throttle servo glitch and actually blocks commands from my tx sometimes...........I'm serious, ill be at 3/4 throttle for a few seconds and itll close my throttle for no reason for a brief second or two while I'm holding 3/4 steadily. does anyone else have this issue? I want to get rid of it and get a futaba but if its still going to happen I might take the chance and run without one and get a real strong throttle return setup. My battery is in a rush box so I'm not too worried about losing it on a hard landing and if my linkage should break off the throttle return spring or rubber band should do the trick, my dx2 has built in failsafe for loss of range, I haven't been able to get is successfully setup but I'm sure with some time and patience I can figure it out. what do you guys think?
I had the same thing happen. When I checked the wiring I found that I put the receiver lid on and pinched the battery wire. It didn't look bad but it must have been enought to short out. I tried another battery and it fixed the problem.
