Offset ?
Zero = no offset. just like the stock rims that come with the savage.
1/2" offset = means that your truck will be 1" wider as the rims extend out 1/2" further than zero offset.
3/4" offset = means that your truck will be 1.5" wider as the rims extend out 3/4" further than zero offset.
i run the maximizer beadlocks with 1/2" offset & they make the truck more stable.
ive heard that the 3/4" offset are mostly for truggy but I'm not 100% sure on that.
1/2" offset makes the truck ride really nice. I was running RPM revolvers with 1/2" offset at the finals and the truck cornered so nicely.
Very helpfull there frddy... This helps me (still a newbie to somethings) alot..Thanks....:jamout:
if you got go xl drivetrain AND offset.....that savy would turn on a DIME!!! check out my vids and you will see......almost impossible to flip....even on tarmac........
Hey, i've got a set of ofna 1/2 offset. running the xl stocker tires. it a pretty lethal combo on the savy x. very stable
geronimo you need to try the xl axle setup WITH offset wheels and watch it!!
