Martin Haas
- Location
- Panambi, RS - Brasil
Since I've never seen the inside of an octane battery box it simply looks like you reorganized it?
Yeah I have had nothing but trouble out of mine same as you, I just keep sending it back.Hi Jeepjunk94,
Now I'm starting to forget the hurts that this octane brought me.
I remember that:
1 - The engine will not start (I disassembled carburetor to review, adjust the needles of all possible ways and nothing, the engine only started when I close the gap of the spark plug to 0.3mm).
2 - After run with the truck the servos from throttle and steering is twitching.
3 - Broke the recoil spring (repaired)
4 - Broke a pin / screw that hold the second gear (changed)
5 - The engine does not start after warm (changed the ignition system) (stop the twitching from servos)
6 - Broke aluminum exhaust pipe (build a new in iron)
So far was only hehehe ...
Now him worked fine after many hours of adjusts and repairs.Doesn't look like it has any problems doing wheelies. 😉
Hello,Looks good what did you use to put on the coil wire for installation is this helping the twitching issue with the rig
[QUOTE="do mean by you change the CSI box like got a new or a different one thanks let me know because my rig runs like a brick shithouse. Thanks for your reply at least one of these $900.00 plus paper weights are able to run decent and thenbring enjoyment and not be a great major waste and big disappointment that everyone has. Good luck I really feel like hip screwed all of us bigtime iI have a boat loaf of savages nitro all the series pretty much and loyal to hpi. So who knew that hpi made a great bog boo boo and fave all of us big shaft and no one drop of customer support and tips for the pig we are all stuck with we can't even get a refund of our money spent on crap we don't want to have a hip credit for what more garbage. Thanks again hpi you guys are the best Happy Holidays.
I am happy that my ideas have helped you improve your truck.Thanks Martin, I just rearranged my box similar to yours. Batteries on top... smacks forehead. Awesome!!! And the pic above, I never thought about using a cable sleeve on my plug wire. I did use heat shrink on my steering servo line (learned that lesson the hard way), but there are some very cool ideas here. Thanks guys.
