W
whipnet
Guest
Ordered the part directly from Nova RC and they shipped very quickly. Upon inspection it's obvious - like their other parts - it's a high quality CNC machined piece. It's lightweight and very strong. Made from Aircraft Grade 7075-T6 aluminum. I did not weigh it, but it is lighter than the stock engine mount.
Mounting this thing to the engine is a snap. 4 screws and you're done.
Mounting it to the Savage is an ENTIRE DIFFERENT STORY. Having the screws bolt directly to the engine mount from the bottom is a snap on the stock one. You also can only move the motor right to left making it simple to set the mesh of your clutch bell and spur.
With the Nova mount you have nuts and screws that you have to deal with. Also it's adjustable which means not only does it move left and right, but forwards and backwards too. Getting the mesh set just became much more difficult. Also one of the screws for mounting it to the chassis must be put into place before attaching it to the motor, the roto is in the way once attached.
Having screws and nuts means no easy access to the back screws which means the rear skid plates have to the come off every time you have to set the mesh. OUCH!!
As far as the cooling aspect of it, I have only run it once and I already run cool by using the Nova RC Cooling Head, so my mill should run nice and cool now. (Always checking temps on the block, not the head of course)
Conclusion: Nice piece. Pain to install and maintain.
Quality - 10
Price of $28 - 7
Installation - 5 (it's that high because I did not have to grind anything to make it fit)
Functionality - 5 (Setting the mesh will be a real treat now)
OVERALL - 6.75
(Even with the lower rating, I am still very satisfied with my purchase. Nova RC makes top notch products.)
