Nova Clutch Shims
Byron
I just got the Nova clutches today, in the package there are 3 washers. I would assume they are shims? Should I use these? I read Jesters Nova review (great info!!) and it does not say anything about the shims?
Thanks for reading the my review.. I thought I talked about thoes washers .. (I never used them) Anyway you put them on the flywheel pins. befor you put the shoes on .. It helps to keep the shoes from hanging up on the flywheel .. I never used them b/c they gave me problems when I put my clutch bell on .
Use the washers. Jester is stupid:duh: . (Inside joke) The shims will help to keep shoe wear from dragging on the flywheel. If you cant get the shimming right get the ofna shim kit and it will fix your interference problem.
