2StrokesFTW
well, as some of you may know earlier today, the savage was running perfect, it went 3/4th throttle and it was going great till it ran out of gas completely. Anyways, after it shut off, i set the piston BDC and let it cool down. Mickey also told me to richen the high speed needle up which i did and it was running great. How ever i took it out again with a full tank of nitro, and completely warmed it up to find that it wasnt running as great. IT wouldnt even go 1/2 throttle, i was holding the throttle down to the max almost and it just wouldnt go, i tried letting off but it still wouldnt go, it moves and such but it just wont hit the higher rpm's. I adjusted the high speed needle to a richer setting and it was worsening,and it stalled a couple of times. I leaned out the high speed needle again but not by much and it was still doing the same thing, i played around with the high speed needle and it would just do the exact same thing. Performance sucked today. I also adjusted the throttle trim and still the same thing. I put the high speed needle to the original setting and still the same thing. WHAT THE HECK IS WRONG WITH THE THING?? I just don't know what to do, i wasted half a tank trying to make it run right and still no luck. THe only needle i touched was the high speed needle. I am on the 7th tank of break in.
