no torque??
ttuzun
Hi
i just installed an new spur gear and changed the gear mesh (which was horrible before) and wanted to try whats gonna happen today
i started the engine
but no torque? the engine screams like crazy but the car moves to slow..
the acceleration is horrible
it cant even push itself up a small bump
what might be the reason for anything like this?
maybe some oil in the clutch?
thx
You tightened the slipper down all the way and then backed it off a half turn right? Was Spur/Clutchbell are you running? Have you checked your clutch shoes to see if they were glazed over?
i have the factory clutch belt
yeah i tightened it up...
i didnt check my clutch shoes though..
but my car is really new... i don't think anything happened to them
check for spur gear first, i usually jam a screwdriver into the metal peice behind it so it does not slide then tighten the 7mm nut, if you do not hold the metal peice in back then you will not be able ot fully tighten it. also if the truck is new then oil might have come out of the bearings on the clutchbell and got onto the shoes. so clean them up with some DA or break cleaner and scuff up the bell and shoes while its apart
ok
i did everything for now... but didnt have time to try... i guess there was some problem with the spur gear i fixed that
thx
