No power
faisalbasha
Mr Nonsensical
Why does my esc stop throttle and brake response completely after a couple of medium speed runs? In the meantime the steering is working.
In order to get the throttle and brake back I have to turn off the esc and then switch it back on.
I have the ezrun 150amp pro esc
Any ideas are greatly appreciated.
What batteries? Whats your motor temp? esc temp when it cuts? 150a is a hefty esc and can draw a big amperage. If your batteries don't have a good size C rating and the motor tries to draw amperage the esc can't deliver it could say "up yours". I ask about temps because the esc most likely has a temp failsafe and is protecting itself if the temps are high.
I found the solution. I charged the batteries and everything is working fine. Looks like the cut off limit for the batterie is a little high because I barely rant ran thee truck a couple kf times and stopped working. Thanks for the advice.
The esc is really cold even when the batteries are empty. I think the voltage cutoff is really high therefore I need to buy the programming card to reduce the voltage cutoff. The c rating I'm not worried about because it's 35-70c discharge.
