Comeseercauto
- Daytona Beach, FL
Been in the lab tryna perfect the V2....long way to go....but looking good...
If it's an XL flux then yes, don't have a flux myself only nitro models but in answer to your question yes it will fit but won't last 5 minutes. The flux has just 1 speed in the gearbox and all the gears are metal. The nitro gearbox has 2 or 3 speeds and the main gears are plastic, which will strip the minute you hit the throttle. You only need the 1 speed on a flux same as in all electric vehicles. The casings are the same but the internals are completely different.Btw can you add the center diff from the xl directly to the flux x?
ah got it thx!If it's an XL flux then yes, don't have a flux myself only nitro models but in answer to your question yes it will fit but won't last 5 minutes. The flux has just 1 speed in the gearbox and all the gears are metal. The nitro gearbox has 2 or 3 speeds and the main gears are plastic, which will strip the minute you hit the throttle. You only need the 1 speed on a flux same as in all electric vehicles. The casings are the same but the internals are completely different.
Yes. I got it for m HRPBtw can you add the center diff from the xl directly to the flux x?
From the Version 2 Yes, I dunno about original SavagesBtw can you add the center diff from the xl directly to the flux x?
