ShiftPoint
- Ft. Laduredale, FL
Has anybody ever tried one of these, or any other N02 injection on there savage. Soundl like it would be pretty cool just to have the extra power when you want it. they have the momentary switch installed so it is depressed when you go to full throttel but I think it would be nice to install a micro servo and have the boost on a button. they claim 20% to 45% power increase.
http://www.rbinnovations.com/catalog/index.php/cPath/34?osCsid=10f633b1ba86bfb2e6a74ba8d2cdf341
I am really tempted to get one of these (talk me out of it), the fuel cells are high from them but I found them a lot cheaper, like $9 for a box of 24 cells instead of the $34 bucks for 30 of them.
Here are some pics of the system installed, figured I would add them to the first post.
this first pic is the switch, it is called a Picoswitch and can be bought here http://www.superdroidrobots.com/shop/item.asp?itemid=828&catid=70 it is nice because they plug right into the rx and is small enough to fit in the front of the radio box easily. I am going to attached the female connector and will do the same with the male on the N20 injector so it is removable. I also put a peice of heat shrink around the switch just to protect it from getting shorted out (not shown in picture
here is it installed in the radio box
and what it looks like installed
this is the wiring diagram and extra componets needed.
I will update the post again after I run it.
