ShiftPoint
- Ft. Laduredale, FL
Hello,
Hi, I am new here, I think I found the right place, I hope I picked a good first truck.
I have a Savage X 4.6 RTR. My first, My first nitro in many many years, since I was a kin before 1976.
I went out to do the first tank of fuel for break in. I had it up on boxes, all idle screws were at default factory, or flush with the casing. Ok I read the instructions up to this part very well a couple times. However the truck will not idle. It starts, runs a bit then die’s, now if I give it a bit of throttle on the tx it will run, I mean very little, I then back off and just before it is at the resting spot for the trigger the truck dies, even if I let it run for a while first.
Finally I tried to adjust the idle scew by turning it clock wise just a small bit, I did this several times, still it acts the same.
It seems to me it is running very rich. I smell un burnt fuel, and when I brought it in and gave up for the night I noticed oil, well I thought it was un burnt fuel, but when I felt it is feels like oil?? I assume this came from the un-burnt fuel evaperating?
Please help, I don’t know what to do, the temp when I measured it is between 125 and 120 degrees F.
Oh, I noticed the servo chatters when ever I touch either a screw driver or the roto start to the frmae or motor, it seems to stop after it makes contact and seems to be more the steering than throttle.
Thanks much,
John
Thanks much,
John
