MikeK1981
ChondroManiac
- Location
- Humboldt, CA
Okay, I had the engine running sweet but it was running between 270 and 290. When I started out it had half a tank and when it ran out I refilled it and to out into the street so I could test the shifting. I immediately started having a problem with it not getting warm enough and stalling when I let off the throttle. Could this be the half tank lean issue I've heard so much about? I mean it went from running good but really hot, then back to the stalling problem and running too cold. Does the tank level make that much difference? I turned the HSN like a quarter turn clockwise from where it was running good trying to lean it out more and it was still stalling and having a hard time warming up. Is this the tank level or do I just not have my needle right yet? Also, the I did adjust the LSN a little clockwise and it seems to have really good throttle response and acceleration, it even runs smooth at top speed it just keeps shutting down on me when I let off the throttle. You can hear it bog a bit like it's loading up on fuel or something right when you let off, or could it be running out of fuel when I let off? All signs seem to point to the fact that it's too rich, slightly wet plug, cool running temps, stalling. I'm going to have to run it from half tank again to see how it acts. Other than this problem the truck is great, very fast, wheelies pretty easy at low speed. I just need to lower 2nd gear a little more and solve this stalling issue and it will be good to go. What is the best way you guys have come up with to address the half-tank lean issue?
