new mylaps rc4 transponder
BIGDAN89
Am I Banned Yet?
las vegas
as i promised some guys from a a earlier wanted transponder add i have new info about the new version of amb rcs transponder.
Because the new MyLaps RC4 Timing System will not be available at all clubs and tracks at once, the MyLaps RC4 Hybrid Transponder has been released to make life easier for everyone. It works on the new MyLaps RC4 Timing System, so you are well prepared but is also 100% backwards compatible, working on all current Mylaps RC2 and RC3 Timing Systems.
RC4 Transponder features:
- Half the size and half the weight of the RC2 Transponder
- Comes with a separate holder, so you can easily switch transponder between cars and boats
- Better quality cable (PTFE) that is racing fuel resistant
- Low voltage operability: 2.8-16 Volt compatible
- 1-4 cell LiPo compatible
- It will be your parent transponder and it comes with Car ID 0 (zero), the default Car ID. You can add child transponders, with Car ID 1, 2, 3, etc. (available soon)
- Any MYLAPS RC4 transponder can always be replaced by a new one that inherits the same Transponder ID and Car ID
- CE approved
Transponder benefits when used in combination with the new Mylaps RC4 Timing System:
- More data measured (temperature, voltage, Car ID, as listed in the communication protocol)
- Double hit rates detection, resulting in even more accurate results
he MyLaps RC4 platform is based upon an entirely new communication protocol for sending over data from your transponder to the timing system installed at the track. The current MyLaps RC3 (previously AMBrc) protocol only allows a transponder to send over your unique transponder ID. With the new RC4 protocol, a transponder is able to send over much more:
- Temperature: the ambient temperature of the transponder
- Voltage: the supply voltage of the transponder
- Car ID: the Car ID allows you to use multiple transponders that share the same unique Transponder ID, but are tagged with different Car IDs. More information will follow soon.
- We will continue to add more relevant data, which you can use for analysis and to improve your performance
After years of research and development we are proud to introduce the new MYLAPS RC4 platform for RC timing and data services. In 1982 we invented automatic timing solutions for the worldwide RC community, and since then we kept improving it. Now, in 2009, we bring an entirely new platform to further enhance your race experience.
The MYLAPS RC4 platform has the following elements:
An enriched communication protocol: the standard on which we develop all new RC products and services
A new series of transponders, based on a complete redesign
A new timing system for clubs and organizations
Source: Mylaps.com
The MYLAPS RC4 platform is based upon an entirely new communication protocol for sending over data from your transponder to the timing system installed at the track. The current MYLAPS RC3 (previously AMBrc) protocol only allows a transponder to send over your unique transponder ID. With the new RC4 protocol, a transponder is able to send over much more:
i already had a thread about this months ago alex try searching and merging yours with mine
Yes they are backwards comparable.
I can't Dan I have none of those fancy dancy mod powers. Maybe someone else will.
get them now before they do the same thing they did with the old ones. they started at 50 bucks when they came out and are now 100.
I want to send one of mine out to get cloned a couple times. Soon, I guess.
