New LRP .28 Spec 3; Lovin' it
leslie
hollis, nh
Hi all,
I finally got my truck (Savage X ) out today with her new powerplant. I had a ball!! I ran 5 tanks through just rolling around the yard, even 1/2 throttle was pretty impressive.
I just got one tank in to start tuning and boy I can tell this pup is going to want to run.
One question, every so often she would just quit. I could not pull the pullstart. I'm assuming vapor lock, as I loosened the glow plug and got her back in order. Is this normal when running very rich??
Cheers,
Leslie
More than likely the sticking you are getting is from the Piston sticking a TDC because of the tight fresh pinch. This is normal for a while. It is probably dying becuase of being rich during break in and you will over come this as well with time.
Good luck and glad to hear you like it.
nice choice, that was my runner-up when i was hunting for a new mill.
you think its fun now, just wait till she run's herself in about 1/2 to 1 gallon. :bolt:
i think your rite tho, id lean the hsn a touch so it will still run a bit on the rich side during your break-in but wont load itself up with fuel & stall.
Hi,
Thanks for the input, I suspected it was just a nuance of breakin. But it's always good to check.
I'm very pleased with the performance of this engine even at the early break in stages. This engine will be a beast, I will have to work on my driving skills 🙂
Cheers,
Leslie
i went with the Picco .28
biggest factor that influenced my decision was that I'm hooked on runnin a modded mill & planned to get whatever mill i bought modded right away.
my buds here thought the picco would be a better choice for modding but some also say that the lrp is faster in stock form.
id show ya a vid, but i blew my front diff locking full brake on asphalt to avoid a collision with my son. just gotta put it back together tho.
