need help with steering
Slimshamis
hey guys whats up i new to the whole savage i just recently turned my truck into a solid integy aluminum, i got some imes jumbo swamp dawg rims and tires on it and a super high torque servo, now the problem I'm having is when i try to turn the servo turns only the servo saver and not the wheels. how do i fix this,is there some type of adjustment on the servo saver to adjust tension?
Servo saver nut? I do not have one it is this purple spring loaded thing that ataxhes to the servo and then the arm goes fro
that to the steering linkage
slim it sounds to me like you have the old style servo saver (kimbourgh design) easiest way to fix this is to remove it and use a solid servo horn with the new savage x style servo saver. then the saver is ajustable like the guys posted before me are saying,
Welacome to :hpisf:
Another thing to check is your pivot screws at the knuckles where they attach the knuckles to the c-hubs. If you have these tightened dopwn too much, they will make your steering bind.
Good way I found to troubleshoot this sort of thing is disconnect your steering rods from the hubs and work your setup independantly by going the steering component by component. You can usually find the issue pretty quickly that way 🙂
And welcome to our addiction - soon to be yours 🙂
Bob
