Need Help with K4.6 Carb kit installation 15241
ogs80
Hello all . I need help with installation of a K4.6 carb kit 15241, Can anyone guide me which are the proper rubber seals on which needle as there are 6 seals with mainly 3 different sizes please ...kindly find attached pic.
Thank you in advance .
@ogs80
THE PURPLE ONE GOES ON CARB SLIDE ( OBVIOUSLY )
THE LARGEST O-RING 1425 GOES ON THE START SHAFT COVER PLATE 1426
THE TWO NEXT SMALLEST 1469 GOES ON BOTTOM OF CARB BODY ,
I THINK YOU ONLY USE ONE, #EXTRA. AS FOR THE REST OF THE TINY ONES
3-2 & 1 REFERENCE THE CARB NEEDLES IN PIC.
I RECOMEND PUTTING SOME GREEN SLIME ON THE O-RINGS SO THEY don't DRY OUT ..
https://www.amazon.com/Factory-Team-Green-Slime-Shock/dp/B07CZQMX3D
@ogs80
Heyyyy thats awsome thanks mate I managed to figure it out finally and have managed to assemble the carb..thank you for all your help and kindness, much appritiated.
