xtremsavage
OG HPISF MEMBER!!!!!
- Jacksonville, Fl
Alright all you search gurus out there. I'm in need of some assistance with trying to find some info. I'm trying to find out what all the specs are on 4 different motors from HPI. The motors are the F4.1, F4.6, K4.6, and K4.6 HO. I already have some info on the two K-series, but mainly need info on the the 2 F-series motors. I mainly need to know HP, useable RPM range, and the max RPM. But if somebody knows of a comparison between the 4 on a side by side list would be great. And this isn't goin into the Savvy, but since they are savvy motors, I started it in the savvy section. This is actually goin into my Schumacher Fusion (1/10th scale on-road car). Unless someone knows of a better engine (needs to be a .21-.28 big block only, no small blocks) with a large useable RPM range and high max RPM, around the same price as the ones mentioned above, please post up. The motor doesn't need alot of torque or power, but mainly the most useable and highest RPMs. The motor I have now for it has way to much torque and it kicks right into 3rd from 1st. And the clutches aren't adjustable. Please help on this guys because I'm missing the 75+ MPH WOT runs.
