SavageBasherxl
Engine is the k5.9
brand new 3 weeks ago.
This is my last attempt to mess with this engine. If you guys cant help me i'm getting the LRP .28
symptoms: engine starts fine, I can go from idle to quarter throttle for about 15 seconds then it stalls. If i go from idle to half throttle it stalls. idle to full throttle it stalls.
what I've tried: factory settings, Leaning only the high speed, leaning only the low speed. Leaning both. checked the mid needle, non wrapping the head, completely wrapping the head (its 30 degrees out), replaced fuel line in case it was clogged, replaced air filter.
factory settings it runs the same as when i turn the high speed in one full turn leaner.
Ive leaned it out enough to where it should blow it up, and still same symptoms.
It sounds like its running way rich the way it bogs down before it stalls.
even if i put it on a stand with no strain on the drivetrain it tacks and sounds good for about a half second then it stalls.
any ideas? If i cant get it running within a few days. its going in the trash.
