pdh 14a
- Swansea,Wales
Right,i've recently changed my exhaust to a tsias,its the one with the little pipe that fires out the ehaust crud at the rear wheel and suspension,after about 10 minutes use the area is getting really gunky and it causes the rear toe arm to pop off!
So as i nebie,i dodn't know if the engine is tuned wrong
or it needs re tuning as i have changed the exhaust and also fitted a little K&N filter.
Should the rear toe arm pop off,or should i put a washer in to stop this?
Any ideas guys? i'll try and put some pics up later.
Cheers.Paul :rock:
Cheers.Paul :rock:
