Form
OK, so I finally (after about a month!) got my o-ring kit and some other parts I ordered (diff gaskets, diff case, etc., stuff that prevented my Savage to run at all) and today my Savy was ready to run. I went to my local quarry to try and run it.
I started it and it sounded weak and "rough" to me, almost stalling. As soon as I applied a bit of throttle (very very little) the engine stalled. I have just sealed my engine real good (I think), including all the needles which are flush/stock.
Damn, it has been almost a month and a half since I could run my Savage, and that's just after my break-in. I hope to get this fixed soon! This is very VERY ******* frustrating... (sorry, I know I shouldn't vent here, I'll go punch/kick something right after posting this!)
One more thing... the pullstater punched a hole in my fuel tank when my engine stalled. Another wonderful 2 weeks waiting for a part to arrive. In the meantime I patched it with some sealant and plastic pieces. It worked at first, but after a while the pressure punctured the sealant. Anyway, the engine behaved the same way even when the tank was OK so I guess this must not be the problem.... or is it? The hole was not there before, I had taken steps to make sure it was 100% airtight while waiting for my o-ring kit.
Also note that I changed my glow plug for a brand new one and it did not change a thing.
I have a few hopeless questions:
1- With all due respect, I guess many of you would tell me my engine is too rich as this seems to be the most common answer in these "stalling when throttle is applied" posts. Is it possible my engine is running too rich with the stock needle settings? Previously it ran fine this way (during break-in). I didn't try to lean it because I supposed it should still start and run fine, without much power of course.
2- What about the tank issue I posted up there ^^^^^^? I think the tank must have been punctured by the 3rd or 4th time the engine stalled. The engine behaved the same all the time.
3- The engine resisted to a little bit of throttle with the wheels off the ground. What about that?
Thanks in advance for any hints, I need those since I'm out of ideas.
P.S: I could post a video of this after fixing my tank again using something else, if you think this could help you help me, then let me know!
:resp:
:resp:
