Msr8
SAVAGESMASH
I Have The Msr8 On My Savage And I Keep Bending The Shafts What Mounts Can I Get To Space Them Out The Screws Come Out Of The Arms And They Tend To Rub On The Arm And The Turn Buckle Can Anyone Help Me Out Thanks
Your better off just runnin 4 shocks total. The two up front will go on the "front side" of the A-arms and the rears will go on the 'rear side" of the A-arms. I ended up switching the screws out that you use to attach them to the lower A-arm for a 3mm machine screw. I used a long enough screw to add a locknut between the shock rod end and the shock mount on the arm. I believe it was a 3x20mm cap head screw. Not 100% sure on the length though. Look into that and see if you like the set-up or not.
What shock oil are you using? They recommend nothing higher than 20. I run 15. As mentioned you can run just 4 easily.
I moved the spacer to the other side in the front to help the rubbing. A 200oz servo helps too. 🙂
I bend mine slightly sometimes, but they pop right back easily. I land mine pretty hard, you just have to make sure you avoid the 1 wheel landings.. as with any shock really.
