tractorman
Hey Guys!!
Long time no read or write!! Just been way too busy unfortunately. I have a question for you all. After a total dumb-*** move thinking that the screw on the end of the crank that holds the clutch bell in place was loose, I tried tightening it only to have it break off. So I've decided to pull the crank and replace it. (I have the stock F 4.6) Now if I'm going as far as pulling the crank I'm thinking that I should be replacing a few other parts such as piston and sleeve as well, just because I have it apart. What other parts should I be replacing? Con rod, bearings, etc? After this is re-built I think it might be a spare and replace it with an LRP. Thanks.
