Catfish Kahn
Hello folks.First off I want to say that I have been a member of this forum for 2 years and have found a lot of help here with the problems I had with my Nitro Savy. I bit the bullet and sold it to buy the Savage Flux HP and I absolutely love it!!!!! I am having a bit of a problem with it and I am hoping that I can find some ideas to remedy my situation.
I am running a Savy Flux HP all Stock. 44t Spur 25t pinion on the Torque 2200kv motor with the Blur esc. I am getting real frusterated because my pinion gear keeps slipping forward on the motor shaft to the point where the pinion and spur are barely touching. It doesn't happen when I just run the truck but when I start to bash and jump it happens.I figure it is because of a hard front end hit and that's what makes it slide up the shaft. I have tightened the set screw as much as I can with out stripping the allen screw and also have used blue loctite to ensure the screw doesn't loosen from vibration.
Has anyone else had this problem? I love my Savy and don't want to get rid of it but if I can't resolve this issue I will go back to Nitro.I am real happy with the Savage and was always impressed that the nitro could take a beating. I am a little disappointed with the Flux because of this issue.Over all I am happy with it but just don't want to have to keep replacing gears because of this. Any help and suggestions will be great.
Thanks all!!!!! Keep On BASHING
