MotoPsycho
- WY, Ooosa (USA)
This mod explains installing a 125cc OFNA fuel tank to help in defeating the tank half lean problem.
Note: THIS MOD REQUIRES RUNNING NO MORE THAN TWO (2) REAR SHOCKS
For a printer friendly PDF: Clicky
Tools needed:
Normal disassembly tools
Drill
13/64" (fits tighter) or 3/16" drill bit
X-acto knife
hacksaw
Parts needed:
Fuel line of your choice
Ofna Tank - Tower Hobbies P/N: LXBM24
Step 1: Drill out BOTH mounting holes with a 13/64" or 3/16" bit
Step 2: Install both fuel fittings into tank.
Step 3: As you can see, the Ofna tank mounting tabs (left) are much thicker than the stock Savvy tank (right).
Mark the new tank across the tab with a sharpie in line (red arrows) with the bottom of the mid tank seam (yellow arrows).
Step 4: Carefully saw (I used a hacksaw) on the line, down close to the tank body (obviously, don't saw into the tank!)
Then score the underside of the tab with an x-acto knife and remove the bottom 1/2 of the tab thickness (red line).
You should now have this:
Step 5: Remove stock fuel tank, fuel lines, exhaust pipe & header, both forward rear shocks, and the rear tank bracket.
Note: I have GPM tank brackets. Rather than having 1 threaded mounting hole and 1 alignment stud, they have 2 threaded mounting holes. If you use stock mounts, I recommend cutting off the stud and drilling so you can have 2 mounting screws instead of 1.
Step 6: You will need to fabricate some sort of stand-off bushings for the rear mount. (I cut down some shock eye bushings)
These stand-offs (red arrow) will keep the tank parallel with the TVP, and prevent rubbing.
Step 7: Install the tank bracket on the outside of the TVP using the stand-offs you made. The screws will be installed from the engine side of the TVP. (This is why you removed the pipe and header.) Reinstall tank, fuel lines, pipe and header, and tighten rear shocks. VOILA! (Va-Whaa-laah; for those of you that don't speak French)
I also run a fuel filter, and attached the bracket for it on the forward side of the rear shock mount with the shock bolt.
Here is my review
Tools needed:
Drill
X-acto knife
hacksaw
Parts needed:
Here is my review
- - I have presently run 3 tanks with this setup, and have not experienced ANY leaning problems.
- - The run times are somewhat shorter, but that was expected.
- - It is impossible to fill the tank with the body on, without hacking on it some more.
- - For about $12 and 45 minutes worth of work, this mod is well worth it.
