Modified 3 speed
Mikey D
I posted this in another section but pics wouldnt show right. Basically you remove the thin idler an drive gears that always break in the 3 speed, and use the 2 speed trans idler an drive gears.(drive gear requires modification). Also replace the only plastic gear with the titanium gear an shim the idler shaft an the shaft the clutches are on. The guy that i learned this from( ikoolskillet from rcuniverse) has a few gallons through it with no probs so far, an hes runnin a clocked picco .28, which as most of us know, will blow a 3 speed apart. Any questions, feel free to ask.
Ok, cool. I knew the how to was at rcu an savage central, didnt know it was here already.
