modded engines
carlg1
does anyone know if a modded engine lasts as long as a stock engine,also if i needed to replace the piston and sleeve in the future could you just re mod the new sleeve if you know what i mean
From what i have read when you get a engine modded you will gain run time and it will run cooler (depends on the modder) and if you run it a good tune not leaned out it could last long and the number 1 enemy for a engine is friction, friction = heat, heat = NO NO, so if you have a good set of bearings the engine could last longer that way also..
BOCA Bearings ::
http://www.bocabearings.com/main1.aspx?p=docs&id=34
when the motor looses compression send the modded sleeve to rayracing. He will pinch the sleeve for 20$ to restore compression to almost like new.
Carl, the guy you want to ask these questions to is Adam of AB Mods.
In addition to being the best in the modding business, Adam dyno-tests all of his work which gives him an accurate and scientific way to measure the work and answer your questions.
Without the dyno aspect, no one can answer your questions any better than saying "i guess" or "i heard" because they don't have a scientific means to test. ;)
https://www.hpisavageforum.com/forums/private.php?do=newpm&u=3790
1. Modified engines can last just as long if not longer then a stock engine. Reason being is due to the fact that a properly modified engine is more efficient. You wont have to lean a modified engine out nearly as much to achieve the power level you are looking for which in turn keeps the engine running nice and cool and keeps wear down.
2. If you are going to replace a piston and sleeve to make it 100% you will need to throw a new rod and a set of bearings in with it. Same goes for pinching an engine.. Even if it doesn't need a new set of bearings at least throw a new rod in.
I can re-modify an engines P/S set after its finally worn itself out. But i always suggest a full rebuild as this time as if the engine has had time to wear out a P/S set its had time to wear the rod and bearings as well.
Thats odd as my website is not up right now as it is being totally re constructed. What is your norton anti virus saying??
General Info
Web Site Location United States of America
Norton Safe Web has analyzed abmods.com for safety and security problems. Below is a sample of the threats that were found.
Threat Report
Total threats found: 6
Drive-By Downloads (what's this?)
Threats found: 6
Here is a complete list:
Threat Name: HTTP Fake AV Redirect Request
Location: http://abmods.com/abm.php?q=bonnaroo-myspace-graphics
Location: http://abmods.com/abm.php?q=bonnaroo-myspace-icons
Location: http://abmods.com/abm.php?q=current-county-snow-emergency-levels-ohio-revised-code
Location: http://abmods.com/abm.php?q=define-snow-emergency-levels-ohio
Location: http://abmods.com/abm.php?q=how-much-are-bonnaroo-tickets
Location: http://abmods.com/abm.php?q=snow-storm-new-york-2007
Ok well these are obviously false positives. Here is the source code to the website. There is nothing like what your antivirus is pulling up. Norton is far from being a respected software these days. I suggest you change to a good and well known anti virus such as Avira or AVG.
This could also be due to spyware on your own system.
I just clicked all of the links that you posted and they do not exist. This is clearly on your end.
This is the raw programming code from the abmods.com website.
PHP:
<html>
<body>
<body bgcolor="#000000">
<CENTER><IMG SRC="http://cx25.justhost.com/~abmodsc2/ablogo.jpg"></CENTER>
<br>
<br>
<br>
<br>
<hl>
<FONT COLOR="#FFFFFF">
<B>
<DIV ALIGN=CENTER>
The AB Mods website is in the process of being renovated to further help our customers. Please bare with us.
We are still open for business. If you wish to purchase an engine or get your current engine modified by the best in the business please contact us through email. Thank you.
</DIV>
</B>
</FONT>
</hl>
<br>
<br>
<hl>
<B>
<DIV ALIGN=CENTER>
<a href="mailto:[email protected]?subject=AB Mods Inquiry" target="_blank" >Contact AB Mods</a>
</DIV>
</B>
</FONT>
</hl>
</body>
</html>
You can see this very same thing by going to the website and right clicking on the page and clicking View Source code.
This is not Adam. This is the Website Project Manager. Hes busy taking care of his customers and modifying engines. Adam wanted me to post under his name because he doesn't know about websites. That is why hes paying me :)
good replies guys, thanks for info frddyj but as its an old thread i have already received my drag modded picco from adam and its an animalhpisfflash piccogirl runs all day long at about 190 to 210 at tops
sweet. lets see a vid.
Very glad to hear you are happy with the engine! LMK if you need anything.
