J
JohnH
Guest
Sure Fire .32
Racers Edge http://www.racers-edge.com
Specifications
Horsepower: 2.9HP No X-Dyno on the .32R to confirm
RPM: 38,000
Engine Size: .32 Cubic Inches ( 5.32cc)
Bore: 19.5mm
Stroke: 17.5mm
Crank: SG Type
Construction: ABC
Weight: 450 g
Carburetor: 9mm Composite
Carburetor Adjustments: 3 needle
Connecting Rod: 7075 aluminum (dual bushing)
Sleeve: 8 port
Type: Rear Exhaust
Plug: Standard
Specifications
RPM: 38,000
Bore: 19.5mm
Stroke: 17.5mm
Crank: SG Type
Construction: ABC
Weight: 450 g
Sleeve: 8 port
Type: Rear Exhaust
Plug: Standard
