Lost Rear-Wheel Power
First check your rear dogbone is still there! then check the diff to make sure it's not stripped the gears, I have known the drive pins in the wheel hex's falling out when changing wheels, if you don't notice the hex will just spin on the drive shaft..I'm gonna guess and say the diff is ready for a re-build..😱(
There's a few things that could cause that.
1. Check your wheel nuts, then take the rear wheels off and check the hubs and rims.
Make sure the little pin is in both axles behind the hubs.
2. Check your rear dogbones, and rear center dogbone.
3. Check the grub (set) screws on the drive cups for the center drive line.
4. Check the diff if all else checks out ok.
Give us a report.
