Losi 1/5 5ive-t 4wd
ljrce
Bark River Michigan
looks like losi stepped up to the plate and wants to play with the baja
Losi 1/5 5ive-t 4wd
http://www.losi.com/Products/Features.aspx?ProdId=LOSB0019WHTBD
Could it be the end of the " I gotta have a BAJA" era. Losi starts out with a 4wd. If HPI does not bring one forward, we all know where the shift will be. HPI has no choice but to bring one to the market and fast. The looks of that Losi is dead on. The body on it could not have been better designed. Very nice indeed. It's also $1500.00. HPI is announcing something today or this weekend. We are all counting on HPI to pull a rabbit out so to speak.Good Luck!
  • Large-bore shocks with 7mm shafts & threaded adjusters
  • 5MM chassis with CNC machining for strength and less weight
  • Two-stage air and fuelfilter systems
  • Powerful Losi® 2-stroke 26cc gasoline engine
  • 1/4 -scale heavy-duty throttle servo for superior braking
  • Adjustable bias dual-disk braking system
  • 1/4-scale high torque metal gear steering servo
  • Extra-large 800cc fuel tank
  • Spektrum SR3300T Telemetry Receiver with 2.4GHZ DSM Technology
  • Three tunable sealed viscous differentials
  • Multi-piece bead lock off-road wheels
  • Impact Absorbing Bumpers
  • Innovative sealed clutch mount with cooling fins
  • Cv driveshafts used throughout
  • 6V 3000mAh Receiver Battery and Charger
Product Specifications
Type:4WD Short Course Truck
Scale:1/5
Length:38 in (965.2mm)
Width:20.75 in (527mm)
Height:12.25 in (311.1mm)
Ground Clearance:2 in (50.8mm)
Wheelbase:24 in (609.6mm)
Chassis:5mm thick 7075 T6 aluminum
Suspension:4 wheel independent
Drivetrain:4WD with 3 silicone fluid differentials & centrifugal clutch
Tire Type:Off-Road all-terrain Performance high wear
Motor or Engine:26cc Gas
Radio:BND - Spektrum 3300T Telemetry Receiver
Batteries:3000MaH 6V NiMH receiver pack
Charger:Global AC charger
Wheel Size:4.75 in (120.6mm)
Kit/RTR:RTR
Shock Type:24MM diameter oil filled with compensation bladders
Body:4 piece, Short Course Truck
Ball Bearings:Throughout including steering
Fuel Tank Capacity:800CC
Minimum Age Recommendation:14 years
Experience Level:Advanced
Recommended Environment:Outdoor
Is Assembly Required:No
I'm loving the looks of this one and its 4wd! Laid out like a truggy this is killer bet it handles like a dream .
I've never been a fan of plate chassis. I know most are built around it but it wouldn't stop me from buying this losi if I was allowed to sell my 5T
