Little Help Please....
Scott
Cry Me A River!!
Ohio
Well juust added a dremel to my tool box for the savy.Was wondering if someone could give me some advice on what bits are good for grinding, cutting lexan and anything else you think might be helpfull..
I've used the sanding disc and drum a bunch of times on my body (I even used the disc to do the Mr. Snuggles Throttle Mod). Also, a grinding stone thingy (kinda like a pencil in shape) is pretty helpful.
id just get yourself an assortment of bits, they will come in handy eventually, I have some cutting wheels, cutting discs, diamond bits of various assortments, polishing drums in different sizes, sanding drums in different sizes, shapes, and grit.you'll use them at one time or another.
I use a rolo-zip spiral bit to cut the body's out just be careful cuz it can take off on ya then go back with a sanding drum and clean up. Like mentioned above the EX lock's are nice to keep on hand as well.
Thanks for all the help fellas.. This will help me out alot..:resp:
