Leaky Carb?
MTBikerTim
Brushless Power!!!
Australia
Has anyone had any issues with their carb leaking from around the slide. There seems to me a lot of fuel leaking out from under the rubber boot on my carb. It's the original s25. I haven't really had a chance to pull it out and have a good look yet so I haven't much idea of what could be wrong other then a stuffed o-ring.
Yea I have had this problem also.. might wanna try a new carb boot .. Other then that there is really nothing you can do ..
I put some rvt sealer at the base of the carb boot .. That helped a little
yeah like site jester said try a new boot but also check ur o rings and before u put them back take sum fuel on a clean finger and coat the o ring if it isnt broken cuz this will presevre ur o rings just a little trick i picked up from my dad when working on my dirtbikes carb it works
