T tert Member Messages 39 Location Sweden Oct 7, 2016 #1 Why do I keep braking my slipper clutch pads on my Savage? I have torn two HPI 72131 within two weeks. Any ideas? Thanks!
X Conspiracy of One HPISF Staff HPISF Supporter Messages 3,384 Location Minnesota Oct 7, 2016 #2 I'm guessing you have the slipper too loose. It should be tightened all the way down.
T tert Member Messages 39 Location Sweden Oct 7, 2016 Thread starter #3 Thanks! Will a loose slipper also cause the clutch pads to melt?
X Conspiracy of One HPISF Staff HPISF Supporter Messages 3,384 Location Minnesota Oct 7, 2016 #4 tert said: Thanks! Will a loose slipper also cause the clutch pads to melt? Click to expand... Yup, causes lots of heat when the slipper is slipping.
olds97_lss Well-Known Member HPISF Supporter Messages 2,627 Location Dekalb, IL 60115 Oct 7, 2016 #5 As soon as the slipper slips, it glazes up and then becomes impossible to lock down. If your running plastic spurs, it will heat up so bad it melts the center out of the spur.
