Keeping Savage Clean
guinnessdublin
England
Since coming out of lock down & being able to get out more with savage on the right side of summer, have found the best/quickest way of cleaning truck after a blast is by using my portable air compressor works a treat!
How do you keep yours clean?
I use soap and water on the body, then spray wax it, for chassis I blow off the gunk and if I need to I break out the brushes and make chunks fall off ,then hit it with denatured alcohol diluted 50/50 with water to clean up then air blow dry again.. I always steer clear of servos and radio box when possible, you can also use diluted simple green to do the same job but you have to rinse well with water, A CLEAN truck is so much easier to look at and work on..
