Form
Ok, I have been trying to tune my Savage the last 2-3 times I had the occasion to run it. The thing is, it always managed to overheat very quickly (the engine was lean, I could hear it), with the HSN very rich.
This time was no exception, I left the engine at stock settings (all needles flush) and ran the Savage for a minute or two before checking the temp. After a very short while, the temps were in the 250-260-270 fahrenheit range, and the engine sounded very lean. I shut it down, put it to BDC and let it cool for a while.
I tried to remove my Axial fuel filter because I noticed there was air bubbles in the fuel line, thinking this could be the cause of my problem. It seemed to help a bit (it ran a bit more consistently) but the engine still overheats like crazy after a couple of minutes.
I don't think I always had this problem, the engine seemed to run OK before and I checked temps during break-in and they were OK too.
When I got my kit I removed the engine back plate to add some high temp gasket maker, as well as the needles to add some green slime on the seals, based on the video tutorials by Squirrel which you may have seen. I'm pretty sure I did a good job so I don't see where there could be air leaks of any kind.
This is driving me crazy, could anyone help?
Conditions:
Glow plug: Cold R5 (stock)
Outside temp: about 15-20 degrees Celcius / 59-68 Fahrenheit, dry
Pressure: Sea level
Conditions:
Pressure: Sea level
