J Concepts wheels with Dirt Bonz
JoeGuam
Virginia
Ok so there are two diffrent types of J concepts. No 3310 and No 3311. The difference is that the No 3310 Diameter is 3.97" (101mm) Width: 2.32" (59mm), No 3311 Diameter is 100mm (3.94") Width: 57.5mm (2.26"). I remember some time ago someone mentioning using the wheel No 3310 and/or 3311 with Dirt Bonz tires. I got the Rulux Half Ups 1/8th truck wheel No 3310. When it came to fitting, the Dirt Bonz tires were challenging to fit over the wheels. The following pictures show the fit and my concern is the stretch.
Width compaired to the maximizers
Tire mounted
Do you see any concerns? Did I purchase the wrong wheel for the Dirt bones No 3310 or 3311? Lastly is there a big difference in performance between the Dirt Bonz S and XS
I could be wrong but, I have been searching for some decent 1/2 offset dish wheels and finding alot of LPR wheels which are 100mm in diameter where as a MAXX tire is about 90mm in diameter. I believe the wheel you should have ordered is 3308 or 3309 depending on offset desired. The combo you have there looks a little stretched but it may work ok. Good luck.
