Is This Idle Adjust Screw ????
R6 DADDY
BLACKBURN (ENGLAND)
HI I HAVE JUST RUN MY SECOUND STATIC TANK OF FUEL AT IDLE (YAWN)
BUT I THIN THE IDLE MAY NEED TO BE ADJUSTED I THINK I CAN SEE THE IDLE SCREW BUT UNSURE IS IT THE ONE OVER THE ZIP TIE ON THE RIGHT
THANKS EVERYONE
CHRIS
sorry caps lock was on
how boring is running in ???????
:chainkiller: :bang:
nope thats the screw that holds the carb in, don't go adjustin that!!! idle is pokin out diagonal from carb, its right behind the fuel line in that foto, u can just see the corner of it.
on my surefire its a flat head screw same on that mill also LOOK AT YOUR CARB CLOSELY ....you will find it its a flat head screw the only one ON your carb
i will look tomoz don't fink it should make it hard work to star though do you i ahve to blip throttle usually any ideas
:shocked:
take your air filter off and look at your throttle slide it should be about 1 mm open when the brake is applied
